What is the correct serial number for an early 65 F.I.??
65 Alternator numbers
693 was base 37 amp rated, used thru 1967
or maybe even later on (what I am told are still refered to as) Corvettes. Fuel Injection, if no K66, didn't require any additional amperage. The 694 (55 amp) was for A/C cars without T.I.
The 695 you mention is a 32 amp rated alternator which I believe was found on Corvairs and maybe other small cars.- Top
