The rebuild went well(?)on my speedometer, but for some reason the needle doesn't move. I have taken it apart again to see if I can figure it out. There is a small spring on the needle stem, do you have to somehow "load" the spring in order for the needle to move? What didn't I do and how do I fix it? Thanks. BTW- The odometer roller turns fine when I hook the cable up to a drill.
Garry
Garry
