Thanks to everyone for the answers on "replacing tires". I now have new tires mounted, balanced etc. for under $300.00. The wheel weight are on the inside too.
The next question is; Should I install the little safety pins to keep the knock off spinner from unwinding? Some of the grooves in the hub don't line up with the grooves on the spinner when the spinner is hammered on tight. Now what? Is there a shim or something to get the grooves to line up? If I get a flat on the road, how do you get the pins out?
This is my second Vette. The first had mag wheels. I hope these questions don't sound too dumb.
thanks,
Ed
thanks,
Ed
