a C4 coolong question - NCRS Discussion Boards
  • Ty T.
    • June 30, 2004
    • 72
    I know it's a little out of our league here, but hoping someone can help me with a cooling problem on my 93 Corvette. After replacing the water pump it heats up, and in a hurry. I loosened the bleed screws on the thermostat housing and at the bypass hose until coolant ran out. I then thought by some strange coincidence that the thermostat was not opening (another symptom is the lower radiator hose is warm where it comes out of the thermostat housing, but cool where it enters the bottom of the radiator) so I removed the thermostat, and it still overheats. As an afterthought I was afraid I may have reversed the two large hoses on the recovery tank, so I switched them (I currently have the bottom hose running to the heater core), and it still overheats.
    I'm stumped, figure it's air locked or could the new water pump be bad?(It's new, not a rebuilt) The water pump is the style with the drive shaft coming in the back of the pump.
    Any help greatly appreciated!!
    Ty
    • 15573
    Re: a C4 coolong question
    Is the coupling on the back of the water pump installed? Wouldn't be the first time someone forgot to install it.
    The reverse flow cooling of the Gen II LT1 helps to make this one of the most difficult to fill cooling systems. It sometimes helps to get the nose of the car as high as possible while bleeding the system at the thermostat housing.
    Can't tell you about the heater hoses -- all my experience with this engine is in a B-body, and I suspect the heater hoses are different on the Y-body.
    • Ty T.
      • June 30, 2004
      • 72
      Re: a C4 cooling question
      By coupling, do you mean the small shaft sticking out the back of the water pump? If so, I remember having to turn it a little to get the water pump to seat flush against the block.
      Any way that you know of to tell if the pump is working without removing it?
      Thanks for your help Terry.
      Ty
        • 15573
        Ty -- there is a coupling that connects the shaft on the back of the water pump to the shaft that comes out of the timing cover. Yes, one has to rotate the shaft on the back of the pump to align the notches in it with the notches in the coupling. It sounds like you got that right, if the pump easily fit flush against the cylinder case.
        I think one can look down behind the pump and see the connection while the engine is operating. Looking at that should tell one if there is power input to the pump. I don't know what happens if one removes the front cover from the pump. I do know those little screws on the front cover will strip out easily. I know someone -- no it wasn't me -- who did that. I've never has the front cover off the pump, but I have a couple of used pumps in the garage. I'll go take one off after work.
        I did hear of a case of a water pump purchased from one of the automotive mass merchandisers that was assembled improperly in the rebuilding process. Where did you get your pump?
        • Ty T.
          • June 30, 2004
          • 72
          I'm quite sure I got the shaft in the coupling as I think the coupling stayed with the engine. Had it not, I'm thinking I would have been looking at a shaft similar to what protrudes from the back of the water pump. I recall putting the shaft in to a hole, which I'm thinking was the coupling.
          I got my pump at a local parts supplier. They mainly wholesale to repair shops and quality is usually good with them. It is a new pump, not a rebuilt, although I suppose that may not matter.
          Another thing I forgot to mention. When I filled the expansion tank, the Haynes manual said to leave the cap off until the engine reaches normal operating tempurature, but it was pushing coolant out the filler neck. Don't know if that has any bearing, but thought I'd let you know.
          Thanks again for all your effort.
          Ty
          • David M.
            • September 30, 2004
            • 515
            You should see coolant moving around with the engine running. I suspect your radiator is clogged with crud. You can try to flush but if its never been done your better off taking it to a radiator shop. They will tell you if its shot or can be rodded out. I'd just replace it if its scaled up.
              • 15573
              • Ty T.
                • June 30, 2004
                • 72
                Re: a C4 cooling issues (long)
                Thanks again for the help guys!
                Dave the car ran fine, until I changed the pump. Always ran cool. So, I'm not suspecting the radiator at this point. I will however keep it in mind to bring a solution to this problem.
                Terry,
                Thanks for the info on the bleeder set up. It was hard to tell air from coolant by just loosening the screw. I'll use your advice to bleed it out. As far as the temp sender, I'm at work, but I'll confirm it tonight, but I believe it was 2 wires going to the sender on the front of the water pump. And you are probably correct about the false reading. The reason I say that is that the car reached 240-250 degrees very quickly and when I shut it off, it didn'y act as though it was overheated. If the temp sender is not 2 wire I'll post another message to you. I'll check the coupling to see if it turns too. Thanks so much for your input!
                Ty
                  Ty-----
                  Is the replacement pump a GM or Delco pump? If so, the thermostat and thermostat housing are supplied with the pump. I would not expect a problem with the thermostat if it's new and supplied with the pump.
                  Just to be sure that you have the correct pump (assuming that it's a Delco), it should be GM #12527739 or Delco #251-554. 1992 pumps are different, although it's unlikely that's what you have since they lack one of the fittings required for 1993-96 and that should have been instantly recognized when you did the installation.
                  • Ty T.
                    • June 30, 2004
                    • 72
                    Joe,
                    The pump is under the brand name of "Parts Plus", but I'm not sure who the manufacturer is. The number on it is WP9001. I looked it over before installing it and it looked identical. It did not come with the thermostat or housing, so I used my old one. I also tried it without the thermostat after it overheated to see what it would do and it acted the same. I'll keep playing with it. If you come up with any ideas please let me know. I know you are awfully busy with this forum and I do so appreciate your help.
                    Signed, "Stumped in Rochester"
                    Ty
