Help please! I keep hearing about "raising" old number stampings with some sort of acid etch method. Can someone explain exactly how this is done? Thanks in advance, Robert, Cincinnati
ACID ETCH
Re: ACID ETCH
Robert-----
What you inquire about is, basically, a forensic technique. It's primary use is to determine what characters may have been previously stamped into a metal piece USUALLY for evidentiary reasons in a criminal case. However, it can be used for other purposes. While this technique can be used to determine what numbers were once stamped into metal, IT WILL NOT permanently restore the numbers/characters; it will simply allow one to determine what stamping was previously present. Also, it's not always successful and, even less often, completely successful.In Appreciation of John Hinckley- Top
Re: ACID ETCH
Thanks very much folks. I have found a Metalllography Forum on the web that has loads of information on Fry's Reagent, and many other etching solutions used to "color" the micrograin in metals, or as some say, to reveal the "plastic deformation" in the metal- sometimes used in forensic metallurgy.
A much cited book apparently contain many different formulas for etching solutions- Metallography Principles and Practice by George VanderVoort, McGraw-Hill, 1984, ISBN 0-07-066970-8.
Also, one can try a Google search for "Fry's reagent in forensic metallurgy".
Thanks again for the tips,
Robert.- Top
