C2-Amp Gauge - NCRS Discussion Boards
C2-Amp Gauge
  • John Lokay
    C2-Amp Gauge
    For years when starting up and driving my 1966 coupe the amp gauge needle pointed dead center, and sometimes at start-up it pulled a little bit to the right. However, last night, when I started up the car, and took it out for a drive, the needle pointed, and stayed the whole time, at the right hash mark situated between the middle mark and the extreme right mark. What gives? I did however, since my last drive, change the low beam headlights by replacing the T 3's with new Halogen headlights. Could this be a factor? Thanks
  • Michael W.
    • April 1, 1997
    • 4290
    Re: C2-Amp Gauge
    Sounds like your regulator is misbehaving.
    • Jack W.
      • August 31, 2000
      • 358
      Re: C2-Amp Gauge
      Also check to see if you lost a ground - jump a wire from the neg post on the alt to the base of the voltage reg, and see if that clears it up.
      • Joe R.
        • March 1, 2002
        • 1356
        Re: C2-Amp Gauge
        Hi John:
        You don't mention whether having the headlights on or off affects the gauge reading. That might be a clue as to whether the headlights are a factor.
        By the way, I have heard anecdotal reports that halogen bulbs draw a lot more current than the OEM incandescent bulbs, and can overstress a wiring system that was not designed for them. This information may not be accurate, but I thought I would mention it as something you might want to check into.
