I am trying to verify the possiblity that the factory authorized a Paxton supercharged LT1 to be built. The story is that the car went directly from the factory to Paxton.
Following is the information I have: Vin#1Z37L2S500783, Engine Block Cast #3970010, Engine Pad V0914CKY(Flint MI plant, Sept. 14, 1971 Assemb. date,350/355 HP solid lifters,4 Speed close ratio trans, ) Secondary # on pad is 12S00783, which matches VIN#. EXHAUST manifolds 3932461RH, Intake appears to be 3972110 LT-1 Holley carb, Polished, rear axle code AB M 181 E1-3:30:1.
Paint and trim codes, Paint 972, trim 400, A23(assem date of Aug 23, 1971
The car does have a tank sticker with it and it shows a CHY 2VLT-1 20 SPECIAL TURBO FIRE ENGINE option.
This is something I am completely unaware of and would like anyone's help in determining whether this is a real car. Thanks.
