C1 283 Cranks & Rods all the same? - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2126
    Can I put the crankshaft and rods from a 1963 283 in my March 1960 ...519 Block?
    What should I do to insure good operation?
    Tom Dingman
    4889
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    Re: C1 283 Cranks & Rods all the same?
    Tom------
    Yes, you can. They are completely compatible. However, this does not mean that all 283 connecting rods and cranks are the same. The ones you mentioned are compatible and completely interchangeable, if not exactly the same. No mods will be necessary. However, as always, you should have the complete reciprocating components precision-balanced before installation. This includes, crankshaft, connecting rods, pistons, harmonic balancer, and flywheel.
    By the way, I don't really recommend the early 283 or 327 connecting rods for use in rebuilt/restored engines. They may be adequate, but they make me nervous. A better plan is to obtain a set of later 327 connecting rods (they were once known as GM #3864881, are GM-discontinued, but available in rebuilt form from some engine parts sources) or aftermarket rods.
    • Tom D.
      • 2126
      Thanks Joe! *NM*
      Michigan Chapter
      Tom Dingman
