Any help will be greatly appreciated. I have an aluminum powerglide that bangs on the down shift and works perfectly fine on upshift. From a previous discussion board posting I checked the vacuum, replaced the modulator canister,adjusted the idle, and verified that the modulator valve moves freely.
I was just told that I should have three parts : a valve ,a small spring, and a pin which fit into the modulator hole in the tranny. I do not have the small spring. since this spring seems to be what will solve my problem, so I am told.
I would like someone to agree or disagree. If you agree do you know where I could find one. I have already emailed many sources on the internet with no luck. Sorry for the length of the posting but as you can see I am in trouble. Thank you for any help you may offer.
