'58-'62 T-10 4 speed part #s - NCRS Discussion Boards
  • James B.
    • September 30, 2005
    • 115
    Can anyone tell me what the part #s are for the T-10 BW 4-speeds from 1958 to 1962?
    I was told that for '58 the # should be 1548631, but confirmation of that would be great as well.
    Jim Brady III
    1959 Corvette Registry, Webmaster
    NCRS #44671
    Re: '58-'62 T-10 4 speed part #s
    Jim------
    "1548631" does not look right to me, at all. Anyway, the SERVICE part numbers, which may or may not be the same as PRODUCTION part numbers, are as follows:
    1958= GM #3743441
    1959= GM #3772337
    1960= GM #3772337
    1961= GM #3783311 (aluminum case)
    1962= GM #3817371 (wide ratio)
    GM #3813489 (close ratio)
    If the PRODUCTION numbers were different than these numbers, I would expect them to be "very closely related numbers".
    Also, keep in mind that these numbers are the part number for the complete assembly. Except as may be found on a metal tag attached to the transmission, they are not otherwise found on the transmission. The metal tag is easily removed, lost, destroyed or CHANGED.
