C3 wheels - NCRS Discussion Boards
C3 wheels
  • Douglas B.
    • May 31, 2006
    • 31
    C3 wheels
    What is the recommended procedure for polishing the original wheels on a 78? They are in good shape, but very dull. I don't have a good reference of what they should look like. Any good resources would be helpful.
  • Tom R.
    • June 30, 1993
    • 4081
    Re: C3 wheels
    Remove the clear lacquer paint...probably now yellowed with age. Once you've removed the lacquer and depending on condition use the polish of choice.
    Mine had begun to pit and I used OOOO steel wheel followed by wheel polish and now they shine.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Douglas B.
      • May 31, 2006
      • 31
      Re: C3 wheels
      Thanks! I was not sure how shiny they should be, but they look too dull to me. What did you use to remove the clear finish?
      • Tom R.
        • June 30, 1993
        • 4081
        Re: C3 wheels
        Lacquer paint remover but work with it very carefully so not to splash on body paint. I used a small brush and worked in small areas. Of course probably a better idea is to remove the wheel.
        Tom Russo
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Yves Thaens
          Re: C3 wheels
          Doug,
          I did mine with very fine sanding paper : first I used a wet 400 grid and then worked up 600,800, 1200 grid. As I final procedure I polished them with some aluminum polish (the kind you can buy in a bike store)...they shine like chrome.
          The inners, which were painted black have to be repainted.
          Yves.
          • Douglas B.
            • May 31, 2006
            • 31
            Re: C3 wheels
            So were they they originally a bright finish? I wanted to make sure they were not a semi polished look. I want to be within original specs when I am done. Thanks for the information.
