Just took my new 67 out for a spin this evening and there is a very noticeable popping / jerking noise as I make a left hand turn. Am I safe to assume this is the posi-trac unit / clutches needing attention, or could it be a rear wheel bearing? If it is the posi unit, I have heard of people draining the rear end grease and filling it with some type of cleaner (kerosene???), then running it around in circles for a few times, draining this and then refilling with posi lube and it cured the problem. Anyone's thoughts? As always, thanks in advance for your help.
Rex
Rex
