Hi again
My initial thread is archived at the following url -
Now I'm back at home I've had a chance to read your responses properly. I'm interested in the debate about whether you should/should not add a trim resistor to the sender unit. It's clear that adding a fixed resistor to the sender is going to shift its transfer function up by constant amount across the operating range. However I know from previous experience that each of the gauges has a color coded cermamic calibration resistor attached to it, so what about changing the value of this? This would surely be the "correct" way to do it? (in the absence of the correct original sender unit) Which of the two coils does this calibration resistor connect to? I know it goes to ground, but how it connects to the gauge internals, I'm not sure.
As I said in the previous posts, I'm happy now that my gauge is over-reading, rather than my engine overheating, so given that I have a few other jobs to do to the instrument cluster, I think it can wait a few months and become a winter project for me to pop the cluster out. Then I can actually get at the gauge, hook it up to a power supply and variable resistor, and see exactly what's going on.
Cheers
Theo
Cheers
Theo
