C-3 locked out!!! help - NCRS Discussion Boards
  • Wally A.
    • May 31, 1979
    • 170
    have a 1980 with 750 miles that i bought new... well after all these years, i plan on making it road worthy. problem is, i lost the keys... all the keys and stuck on what to do? can a locksmith rekey it, both doors and ignition without to much work other than the cost? what about GM having anything availabe to find the code? thanks wally
  • Terry F.
    • September 30, 1992
    • 2061
    Re: C-3 locked out!!! help
    I am not sure about this but I would think there is some sort of key code that was delivered with your car new. I would try to find it. Might be with the key envelope or in the ops manual. Just an idea. Terry
    • Terry F.
      • 2061
      Also, getting into it depends on the lock smith. Locally, I have a lock smith that has keys for every year car. He has hundreds on large rings. I took a lock to him and he simply just started trying keys. Actually, he gave me a chair and all the keys and said start trying them untill you find one that works. I eventully wiggled one and got it to open. We then took the lock apart and determined the actual key for it. You might have luck like that. Terry
      • GL Anderson
        If the dealer you bought it from is still in business and has the records the key numbers are on the invoice and should be recorded on the car prep sheet. Call them and ask but be prepared to prove you own the car. Also the numbers may be available from Chevrolet, any dealer can call with the serial number and may be able to get them for you.
        • Joe C.
          • August 31, 1999
          • 4598
          Wally,
          Go to the local firehouse, carrying proof of ownership of the vehicle. They should be able to use a "shove knife" and open the door for you, with no damage.
          Joe
          • Harmon C.
            • August 31, 1994
            • 3228
            If you bought it new you should have the key knockouts or paper work that has the key codes on them. If it only has 750 miles on it you better think about a plan of what you want to do with your low mile Corvette. For sure don't try to break in or change the locks.
            Lyle
