How long is the LH vent cable for a '64 w/o AC? I've been putting the dash area back together and the cable I have seems way too long and has some major bends in it, making operation difficult. Thanks.
vent cable length
C2 LH Kick Panel Cable is 17" measured ...
from where the knob meets the under-dash bracket (when pushed in) to the center of the hole on the clip that screws to the plastic vent housing. This is from a non-C60 1965 [I just happened to have the cable on the bench], but should be the same (except for the knob shape, as your '64.- Top
The S-Curve is OK
Do you have a copy of the AIM ? cable goes straight forward from knob, then curves 90 degrees to the left to cross the hood release cable (doing this from memory -- don't have mine handy) to which it attaches with a clip that holds it in this angle; then another S-curve as it approaches the kick panel plastic vent cover.- Top
