I have read most of your questions and responses, with a real question of, If you are planning to make a driver of your '68 , are you also planning on flight judging also. This is good for the correct use of Corvettes, but you need to make some decisions before you jump into the restoration process. I see where you body paint person want to provide additional support for the fenders. From the factory they were fine, unless they were hit and thus the cracks are causing the weakness, in that case you would get deduction for the the damage and the repair if it is not as it was from the factory. Therefore your point deduction can not be determined in this forum.
The first Corvette that I attempted to restore was done after at least two years of research; two to three years of judging experience; and a good two years of photos of other completed and judged examples. You may want to attend a regional this year and hopefully see a good example of a '68 Corvette. Bowling Green in April 22-24 and not so far a trip for you.
