Horn - NCRS Discussion Boards
Horn
  • charlie saliba
    Horn
    Hi need to know how to remove horn button from the steering wheel as i have a problem when the wheel is turned to the left the horn is actavated.
  • Robert S.
    • July 31, 2004
    • 377
    Re: Horn
    It would help to know what car your working on!
    Bob
      Re: Horn
      From your profile, I presume the car in question is a '58. Your copy of the AIM should show the horn ring installation...
      The cap simply presses into the horn contact assy and is held in place by the 'fingers' on the outer circumference of the contact assy. Simply pry the cap off by lifting against an outside, lower edge. Expect the horn to HONK when you remove the button IF your battery isn't disconnected!
      • charlie saliba
        Re: Horn
        C2 1963 coupe
