Shell Rotella oil info - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    The other day we discussed using the Shell Rotella C1-4 motor oil for newly rebuild flat tappet cam engines. Jim said that his local Walmart stocked 10-30W where as most other places only stocked 15-40W. Just reporting that my Walmart had the lighter weight oil by the gallon. Little less thatn 9 bucks. So that's good news. I was sorta leary on using the heavier oil in a fresh rebuild. Buying the GM oil supplement also. Should have lots of zinc and hopefully no cam problems. John
  • Tom D.
    • September 30, 1981
    • 2126
    Zinc comes from the GM Supplement or ? *NM*
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Tom D.
      • 2126
      I've Seen the Diesel Oil posts. *NM*
      Michigan Chapter
      Tom Dingman
        Re: Zinc comes from the GM Supplement or ?
        Tom-----
        The zinc extreme pressure additive would be found in generous quantity in the diesel-rated engine oil and in extreme concentration in the GM EOS additive. So, in the scenario described, the zinc would be found in BOTH the oil and the EOS.
