What I thought was going to be a simple lifter change on my 71 LS5 has pretty much turned into a complete engine overhaul. The engine (original) has never been opened up until now. It has the original steel shim head gaskets. Question is, what type of head gasket is recommended to replace the shim type for this application?
Also, I was planning on replacing the cam with the Crane equivalent of the original. Is there another cam (manufacturer) I should look at? I want to stay as stock as possible but I am not against a small step up in cam profile.
Tom
Tom
