C3 Door Handle Springs - NCRS Discussion Boards
  • john t wilson
    Where can I find replacement springs for a 1972 exterior door handle.
    It seems with a little effort these could be replaced.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 Door Handle Springs
    If you just need the spring I would pick up a few handles at the swap meet that seem to have a good spring. The flat metal instant fix is easy to break when installing and I would say a poor choice if more than a short term repair is needed. I would change the handle it's not that hard. About 2 hours if you have done it before and better have 8 hours if it is your first handle.To change the spring I would say you will need it off the car so I would go new. Big hands will make it harder to do.
    Lyle
    Lyle
