i just bought off of ebay an item that I am trying to learn more about. I suspect Loren, Art or others that worked for GM may know more about this item.
It is a key fob that kind of looks like a "fishing lure spoon". It is about 2" long and about 3/4" at the center widest point. On one side it has "Body by Fisher" with the coach emblem and then next to it it has "styling" "engineering" "research" lined up in that order from top to bottom.
The other side is more interesting. It has starting at the left "General TC Motor" and then next to that it has "Technical Center Dedication May 16, 1956" The material is most likely aluminum and it has a hole at one end clearly to be used as a key fob or charm of some sort.
Can someone give me a few more details on this? Clearly it was some sort of give away at the dedication ceremony of the Tech center. Anything else? Thanks.
Garry
Garry
