1970 front lift bracket vs 1969
see Vette Vues 1968 - 1972 fact book page 91 for the 390 HP 1969 front bracket - no 1/8" hole seen. Then look at page 150 for the 1970 390 HP bracket - see the 1/8" hole at the forward edge? The small throttle return spring is likely incorrect as they usually went back to the throttle cable mounting bracket on the rear carb stud. Just under the small throttle spring, you can see a lottle loop of 1/8" coat hanger-like steel rod that goes over and around the PCV hose. I can't guarantee this is correct, but I bought the brackets from a 1970 BB Chevelle years ago and the seller included a similar coat hanger-like piece. I asked him what "that piece of junk was" and he told me it held the PCV hose. Who knows, but now I've seen it from two sources.
Better question, why doesn't the 1969 have one? It seems this support wire would keep the PCV hose from chafing against the lift bracket.
Mark
Mark
