70 steering column removal - NCRS Discussion Boards
  • David F.
    Infrequent User
    • March 1, 2005
    • 17
    What is the easiest way to remove the steering column from a 70 cpe.I have unbolted it from the dash,cowl,and rag joint, but not sure how it comes out.
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: 70 steering column removal
    It comes out from the top. Make sure you've disconnected the wiring etc. and removed the clamp at the firewall (engine side) from the column. It should pull right out.
