Want to confirm I have the correct radiator for the 72 Small Block with A/C
Per the Judging Manual, it appears the core is correct ie top hat dimensions and holes (1 round 1 sq.) Need help with side tanks identification. Can not locate the small tag that is supposedly soldered to passenger side tank, but manual says may not be visisble due location of tag/seals around radiator. It appears the side tanks are slightly different in size?? It has the correct rad cap.
Are there any other elements of the tanks to look for that can help identify it. The core is definitely copper.
Thanks in advance to all the radiator experts out there for your help!!
