I'm in the process of trying to get my A/C system up and running for my '67 coupe. It has factory A/C. Here's my problem:
My A/C pump won't pump down. The low side only goes to 95 lbs and my high side only goes to 105 lbs. I've tried it with two rebuilt compressors, but the same result each time.
What is causing my system not to pump down? On a day like today (85 degrees), my low side should be around 36 lbs and my high side should be around 280 lbs. I can't believe that it's my pump because I've tried two separate rebuilt pumps. I have all new hoses and a new expansion valve. What, besides a bad pump, can prevent my A/C system from pumping down?
Any suggestions? I'm all ears!
Tony
Tony
