1969 - Radiator Center Mount Bracket - NCRS Discussion Boards
  • Craig C.
    • July 31, 1999
    • 51
    I am rebuilding my 1969 427/390/THM 400/No AC and understand that it originally came with a copper/brass radiator supported at the top by two saddle brackets attached to the right and left sides of the core support. Was a top center bracket also present? No center bracket was attached to the support when I bought the car, however, the radiator had been replaced so I do not know if it at one time was present. I ask the question because the L-36 radiator and support sketch in my AIM shows that it is included.
    Thanks in advance for your help.
    Craig
    #32671
  • David N.
    • June 30, 1991
    • 142
    Re: 1969 - Radiator Center Mount Bracket
    Craig,
    There were only the two outer brackets. The radiator shroud did have an upper center mount.
    David Nims #19639
    '69 BB conv.~~~~~~~
    • Mark #28455
      center bracket goes to fan shroud *NM*
