C2 1963 "N" on Wiring Diagram = Navy? *NM*
  • Tom D.
    • October 1, 1981
    • 2066
    http://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Joe C.
    • September 1, 1999
    • 4601
    Could Also Be "Navajowhite"
    Which wire are you referring to?
    Joe
    • Tom D.
      • October 1, 1981
      • 2066
      Brake light Sw. (white if 66) "N" = Negative?
      Thanks Joe. I should have typed more stuff before. It's shown as 20 guage "N" at the brake light switch (opposite of the orange one). Lots of other bulbs, and door open light swith, give the same indication on the diagram. Probably equals "Negative", but the other codes are all colors.
      I also see "T" for the horn, which I assume is Teal.
      Tom Dingman
      4889
      Michigan Chapter
      Tom Dingman
      • Kenneth S.
        • August 1, 1981
        • 302
        Re: Brake light Sw. (white if 66) "N" = Negative?
        The brake switch wire is White so the N is for Neutral. The Horn wire is Tan.
        • Joe C.
          • September 1, 1999
          • 4601
          Sorry Tom, for the lame joke. You are right about the "N" signifying "negative", and "T" does, indeed, mean "tan".
          Wires are normally coded as either light or dark shades of such "manly" hues as, red, white, blue, yellow, green, tan, black, pink(!), etc. More feminine nomenclature, such as "taupe", "mauve", "teal", "navajowhite", "kelly green", "lavender", etc. are not used (yet?).
          God help us when women (or gay men) begin writing wiring schematics!
          Joe
          • Wayne M.
            • March 1, 1980
            • 6414
            Or "Natural"
            See 1963 Corvette shop manual, Electrical body and chassis 12-2, Fig 2 (labels color of wires going to stoplight switch). Also, 1963 Corvette wiring diagrams use "N" color code in several places. This usage seems to have disappeared by 1965.
            Same thing in plastic speedo-driven gears; the 19-tooth 3860342 is called "natural", meaning off-white, IMO.
              Re:
              "N" on a GM wiring diagram means "neutral", which is the same as "white".
              • Tom D.
                • October 1, 1981
                • 2066
                Thanks - Welcome back! *NM*
                Michigan Chapter
                Tom Dingman
