'66 backup lights - NCRS Discussion Boards
'66 backup lights
  • Todd Muhleman #31307
    '66 backup lights
    Over the weekend I replaced both bulbs on the backup lights of my '66 (burned out long ago). However, after doing so I found that the backup lights are on all of the time except when I put the car in reverse. Any suggestions on what to check?
  • Bill Clupper
    Re: '66 backup lights
    check the switch nounted on the trans, it sounds like someone has mounted it upside down.
    • Gene M.
      • April 1, 1985
      • 4232
      Todd, It sounds like an incorrectly adjusted back-up switch on the transmission. It is possible to incorrectly install the switch to perform opposite as you stated. This is a simple adjustment of trial and error to get right, goes much fasted with a friend to move shifter and check lites as you adjust on the bottom side.
        • Bill Clupper
          It's mounted on a bracket at the rear of the side sover. a link runs to the switch actuating lever from the reverse shifter arm on the trans just rearward of the switch
