61 Resister, Points, Coil problem - NCRS Discussion Boards
  • Jerry J.
    • November 1, 2000
    • 54
    I've searched & searched the archives and can't seem
    to find my problem.
    Left key on and burnt wire to key switch. Changed to a new
    wiring harness. Engine turns over but no fire.
    Afraid to leave key on for any length of time for fear of
    burning new harness..
    To test the resistor, coil, & points for power, should I leave
    points open or closed with key on ?? I have points set at 18 thou.
    Any help & or hints would surely be apprectiated. I'm at my wits
    end... Tks. all. Jerry....
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 61 Resister, Points, Coil problem
    Turn key on then using a trouble light you should have power on both sides of the resistor. Dist cap off you can with a screw driver open points to see a spark telling you it's getting power.
    • Jerry J.
      • November 1, 2000
      • 54
      Roy: Thanks for the response..
      Per your response, both sides of the resistor have power.
      Points do not spark. Now what ? Do you think they might be
      grounded.. TIA.. Jerry.
      • Jerry J.
        • November 1, 2000
        • 54
        Problem solved... 2 new sets of blue streak points, both
        with wick holders.. One was touching the spring on a set
        of points. (I bent it. Ugh).
        Ground off both wick holders, replaced, and car started instantly.
        • Roy B.
          • February 1, 1975
          • 7044
          Simple things can drive one crazy
