Fan Clutches - NCRS Discussion Boards
Fan Clutches
  • Terry van Slooten
    Fan Clutches
    Could someone tell me a process to tell if a fan clutch is working properly? On my 62 the fan will free wheel with no resistance when I shut down on a hot engine. I didn't think this was normal. I've also recently had trouble in traffic with a faster increase in temp than I normally would. Thanks
  • Robert B.
    • March 1, 1992
    • 263
    Re: Fan Clutches
    after you turn the engine off the fan should spin approx 1/2 turns only, sounds like yours is definutly shot good luck
    • Bill Clupper
      Re: Fan Clutches
      I had a similar problem with my '62, Sent it out to Fred Oliva, returned good as new, drove it on road tour to St Louis a couple of years ago with it no problem. email foliva@gate.net
      • Richard E.
        • November 1, 1976
        • 200
        Re: Fan Clutches
        Same results as Bill on my 62. Before I had Fred rebuild a correct clutch for me, his criteria was no more than three revolutions past engine stop. My old one more or less free wheeled after shutdown.......Dick
        • Gary S.
          Super Moderator
          • February 1, 1984
          • 456
          Re: Fan Clutches
          I was taught by someone smarter than me that if you want to check a fan clutch (like at a flea market) just hold the hub and start spinning the clutch. If it spins free, it is bad. I have done this with many at flea markets. At first, there is resistance even in bad ones. You must spin it enough to get it a little warm. Gary
          Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
          • motorman
            Re: Fan Clutches
            also clutch fan units must be stored verticaly, never laid down because it causes the fluid to do something it should not do. does anyone know why?
            • dale pearman
              Re: Fan Clutches
              Yeah.....leak out!
              • Robert B.
                • March 1, 1992
                • 263
                Re: Fan Clutches
                Best way to store a fan clutch is the way it sits on the engine . Ask Fred
