Is their an easy trick to putting the distributor shielding on a BB 67? Thanks in advance.
67 BB ignition shielding
Re: 67 BB ignition shielding
Phil, I have mastered this operation. I install the ignition cables on the distributor cap (but not on the plugs), place the ground wires on the posts and install the nuts. With no shielding installed it makes this operation easy. Now gather up all the ignition cables in one hand and slide the shielding down over them on to the brackets and install the wing bolts. Now just install the grommets, slip the grommets into place and connect at the plugs.- Top
