Today, I tried to open my driver side door on my 1970 coupe and the key turned but didn't unlock the door. I got in on the passenger side and tried to unlock the door from the inside and the door still would not unlock. To make things worse, I tugged on the door pull strap to make sure that the door was snuggly shut and I broke off the pull strap. Looks like I have some interior work to be done now. As soon as it stops raining, you know where I will be.
Now my questions:
How do I open the door (unlock it) so I can get the inside door panel off? My guess is that one of the levers that unlocks the door slipped or broke off some how. I will also have to fix the passenger side door as that one doesn't open from the inside. Has anyone else experienced this and would you share your experience with me?
Also, does anyone know where I can get a good used black door pull strap for my driver side door? I really don't want to get a pair if someone has an extra one sitting around for sale. I guess that won't be a big deal to get a pair of pull straps as the other is also 30 years old and could go any day, too. Also, are the repro pull straps identical to the originals?
Thanks...
Tony
Now my questions:
Thanks...
Tony
