69 427 blocks - NCRS Discussion Boards
69 427 blocks
  • Charles W.
    • February 1, 2002
    • 11
    69 427 blocks
    I am in the process of purchasing a 69 Corvette and wondered if anyone could provide me with some information. What does the 68-69 Corvette Technical Information Manual and Judging Guide say about the correct block casting number for a late September car? From my limited knowledge it looks like either a 3935439 or a 3955270 block, if the casting date is June, July or Aug., could be correct. However, I would like to know what the Technical Manual or other 69 owners have to say about the two blocks for a September 68 car.
  • Jon S.
    • November 1, 1986
    • 166
    Re: 69 427 blocks
    My mid-August built '69 has a 3963512 block with an F 5 9 casting (June 5, 69). I believe it to be the original block, and have never had a problem on the judging field.
    Jon
    #10673
      Re: 69 427 blocks
      Charles-----
      For a September, 1968-built car, I'd say that either block could have been originally used. If the block in the car, regardless of which of these 2 casting numbers, is dated correctly for the car and the pad stamping appears legit, it probably is the original block. If it doesn't have a correct pad stamping, but the casting date of the block is correct for the car per NCRS guidelines, then I believe that the block would be considered correct for the car regardless of which of the 2 casting numbers you mentioned it is.
