If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
When removing the speedometer cable at the 4 speed transmission, in which direction should I manually spin the cable to make the speed indicator pointer move in the speedometer; clockwise or counterclockwise?
I did not want to use trial and error for fear I may damage the spring in the speedometer if I turn it in the wrong direction.
Thank you,
Kurt
Thanks Dick.
I have a sticking problem at the lower speeds but then it runs fine once the speed increases. I was going to try to hook it up to an electric drill to see if I could clear up the sticking problem as the car has been sitting for 10 years. It worked fine before I put it in storage so I am thinking it might be some corrosion that I can work loose by running it at various speeds with a drill.
The odometer registers OK but the speed stays at 0 until you get past 30 or 40 then it works fine.
Thanks again,
Kurt
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
