C2 Ignition Shield Brackets and Finish - NCRS Discussion Boards
  • Alan Drake
    Getting parts ready for winter project. Relative to the Ignition Shielding for a 1964 FI;
    1 The ignition shield support brackets, 3819757, 8, & 9, what is the finish on these and are they painted org? Want to use original ones with correct markings.
    2 The brackets which the ign wires run through and also hold the shielding, are these painted black and what flavor (gloss, semi,flat, ..)?
    3 Have two styles of the lower rear L.H. bracket (those described above in 2)
    One is straight while other has a section which thins then goes back to same
    dimention as started. (can send picture, but no idea how to post).
    Paragon shows two of these, one for 56-69 the straight one while the other is
    for 65-67 but with a section take out entirely while mine only has a small
    section removed (could this be a 63??)
    Re: C2 Ignition Shield Brackets and Finish
    Alan -
    The upper shielding/plug wire supports are semi-gloss black (they were dip-primed).
    The lower 757-8-9 shielding brackets (that are attached under the exhaust manifold bolt heads) were zinc/cad plated, not painted.
    • Alan Drake
      Thanks John.
      My brackets are still dip-primed without any rust - in great shape.
      The lower brackets I'll clean and plate. Have seen a number painted at events and was not sure what they needed to be.
      Any idea of what the other bracket could be from? How about a 63? I did have a number of minor 63 parts around the garage from past work on a friends car.
      Thanks again
