61 short weather seal - NCRS Discussion Boards
  • Richard Geiger
    I kept my 1961 original door short weather seal # 3771847. I have two reproduction seals that look quite the same except that the original has a molding line on the large end. I am almost certain that these seals were screwed to the door. Assembly manual says fastsner # 4653672. Can anyone tell me, is this fastsner a screw with washer, screw alone, or one of those push in weather strip attachment things? My original shows a bit of rust around the attachment hole and I do seem to remember it being screwed on. Thank you for taking the time to look at your original or top flight to respond.
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 61 short weather seal
    They were all the push-in type on all 61 and 62's. Still readily available from GM and Corvette suppliers.
