I need help diagnosing a new noise coming from the rear passenger side wheel. I drive this car daily and just in the past two days this noise came from nowhere and is now so loud, I parked it.
The noise is 'rotational' - faster I go, the faster the metal-on-metal screeching sound -- something like "screeeeech......screeech.... screech..screech.screeech". I put it on the lift and could NOT duplicate the noise. However, on test drives, its seems to be really loud under load/acceleration and almost non-existent when coasting. Also, when first taking off or backing up, there is a loud 'clunk' (bad u-joints?)
A little history: I pulled this car from a barn in December '05(literally). Family owned since 1973, unrestored, not driven since 1990. I put in new brake system end-to-end (new hard lines, 2 new rear rotors, new SS parking brake hardware, calipers,MC, etc); new fuel pump, carb rebuild; all new cooling system end-to-end, and replaced engine gaskets. I've been driving almost daily since February. It has a little more than 60,000 originial miles. All suspension rubber is original, dried, cracked and worn as you would expect a car of this mileage and vintage.
Any help would be apprecaited. Thanks!
