Clutch fork throw out bearing retaining spring
  • Chuck R.
    • May 1, 1999
    • 1434
    Any good resourses for the throw out bearing retaining spring that's riveted to the clutch fork for a 68?
    Chuck
    • 42936
    Re: Clutch fork throw out bearing retaining spring
    Chuck-----
    Originally known as GM #3849698, the spring was later replaced by GM #12337938. That's also been discontinued, but I'm sure there are still plenty around. Most folks usually just replace the whole fork rather than deal with setting the rivet, so I don't expect that GM never sold a whole lot of these springs.
    Your local GM dealer should be able to locate one for you and obtain it from another dealer. This is a part worth only a few bucks, so the dealer might just want you to deal direct with the other dealer. There may even be one available from a dealer right near where you live.
      If all you need to replace is the spring, Paragon sells the spring (including the rivet that attaches it to the fork) for $6.00.
      • Verne Frantz
        Chuck,
        follow this link to p/n 1061A
        Verne
        • Verne Frantz
          I tried the link and it didn't work. Try this.
          Then click on "clutch & transmission, group 5"
          Verne
          • Chuck R.
            • May 1, 1999
            • 1434
            Re: Thanks for the responses Gents
            As always, thanks for taking the time to respond back, I appreciate it.
            Chuck
