63 windshield washers - NCRS Discussion Boards
  • Jerry G.
    • February 1, 1989
    • 226
    Are there any adjustments or tricks to getting a passenger side nozzle to squirt with more force? The drivers side almost shoots over the car. I did switch hoses on the pump, but no difference. Hoses and nozzles are new. Thanks
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 63 windshield washers
    if the nozzles are repos, suggest ya measure the ID of the nozzles to check for uniformity. get a set of numerically numbered drill bits , insert the non-cutting end of the bits into the nozzle outlets to evaluate IDs of both. suspect the non-squirter hole id is larger(if stream is big dribble) or totally blocked (if no quirt at all) than the overshooting nozzle. if so, return defective nozzle for replacement. mike
