Re: Alternator identification-C3
Dick if you are still going to the shop to look up in your Delco book for the application of the 924 would you look up one for me as well. My original owner 1970 with air came with the 62 amp 110844. The 1100844 62 amp alternator was replaced under warranty either in the fall or 1970 or early 1971. The replacement alternator is a 63 amp unit and is stamped 1100554 and dated 0J28. I have not been able to identify what the 1100554 63 alternator was for. The 71 Corvettes use a 1100544 with air. I do remember the service rep telling me when I picked up my 70 with the new alternator that they put on a higher amp alternator. Now if I knew then what I know now I would of just had the unit repaired to keep the original alternator.
