C-3 - NCRS Discussion Boards
C-3
  • Mark A.
    • February 1, 1996
    • 299
    C-3
    I am restoring a 69 coupe and want to replace the steel reinforcing channels that go under the fiberglass sill plates, mine are rusted out. I drilled out the big rivets, but it won't budge, so I believe it must also be glued. Is there a way to get the steel channels out without destroying the body and the channels? Any help would be appreciated. Thanks, Mark
  • Lyle24961
    Re: C-3
    I think you need to cut the fiberglass. Check Corvette Forum.com they may have a FAQ and their are pictures of the replacement
    • Steve Wallach
      Re: C-3
      I am doing a full resotoration on my 68 coupe. I started out thinking I was going to do a simple "body off" restoration, but then found enough rust in these rails to think I would replace them. You are in for a MAJOR job that requires professional help (probably in more ways than one ).
      You will need to remove the fiberglass rail cover, lock pillar and rear fender at a minimum. You may find there is much more rust in more areas as well. If this is not a Big Block car or a rare car, you may want to seriously consider not going any further.
      Good Luck,
      Steve
