I need help with finding and determining what is correct as I reassemble the wire harness, and interior. I have some questions regarding the alternator mounting brackets and the ignition shielding. Also other questions regarding correct fastener and fastener finish.
I would love to find a small block survivior that I can look at, take notes, and take pictures.
I have ordered the JM over a year ago and the AIM is quite vauge in a lot of these areas.
Examples: How is the alarm harness routed around the kick panel area? How is the rear harness routed in the same area? Did the factory use 1/4-20 nuts and washers to attach the tail lamp housings to the body, the wire harness to the tail lamp housings with the washers as shown in the AIM? MIne had no washers but had been disassembled by a previous owner. If washers then I can use a set of original washers and 1/4-20 nuts. Ideally the hardware would come from the southwest for obvious reasons. What do the correct screws look like that attach the rear grills to the rear deck area? I have a lot more and they are typed up.
I just thought looking at a real survivor would be the perfect answer.
Ideally the car would be in Maryland somewhere so I could run over.
If you have one or knoe of someone that does that will allow me to look please call my cell phone at 301-440-0838.
Bill
Bill
