Gas gauge has not worked corretly for some time. Recently removed the sending unit from the tank and cleaned the resistance wire with scotchbrite and re assembled. I checked out the action of the gauge and carefully measured resistance at empty, full and about 1/2 of range. I then set up and checked the gauge by using a potentionmeter set to the same three resistance values. The gauge basically read okay. It worked correctly for some time. However after running for a time the gauge will drift up and read full. Shutting the engine down and turning the key back on gives a correct reading again but If I drive it the same thing happens. I suspect a ground problem in the instrument circuit but I am not sure. Any suggestions as to what may be wrong?
Thanks in advance.
Thanks in advance.
