Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Casting Flaw on Finned Valve Covers -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
All - a friend recently purchased a 1966 Corvette (December B Day). When did the casting flaw began to appear on the the finned Aluminum covers and for NCRS judging is there a deduction? I understand it was in 1966, but not sure when. Thanks
Approximately mid-year, but as to deduction, it varies with the significance of the flaw. Originally the actual flaw in 1966 (and '67 for that matter) was quite light, and not real nitacable. As time went on, and many were ordered thru service, the tooling deteriorated to where the center of the "O" in Corvette was partially filled in and the seam line was quite pronounced. Those were not representative of the factory installed items and would be treated as a service replacement. There is also a large grey area between the extremes that must be navigated by carowner and/or judges.
Eric, Bill Clupper is correct of course with his answer. About March 66 is when the casting flaw (crack in mold) finally broke thru. That's what I have been told when I researched the valve cover info. But as Bill said there had to be overlap on the installation of seamed vs no seam. John
