I have a newly rebuilt motor. When I took off my carbs to do the motor they worked fine. After I put them back they won't idle when cold. The auto choke seems to be working fine. When it gets to normal temp it idles fine (700-750rpm). If I set the idle when cold then when it gets to normal running temp it idles at 1500 or so. I've checked all fittings and they are hooked up and no vacuum leak that I can see. All 3 carbs were new from Holly 4 mo.ago.
Any ideas? What next?
TIA, Roger
TIA, Roger
