Major engine component(s) weight - NCRS Discussion Boards
  • Steve Antonucci
    Hi all!
    I was wondering if any of you can tell me where I can find the weights for
    big block Mark IV major engine components. I've been on-line trying to find
    this information with little success.
    Examples would be:
    cast iron block
    ZL-1 block
    cast iron heads
    aluminum heads
    cast iron intake
    aluminum intake
    cast iron crankshaft
    forged crankshaft ( would the weight be significantly different ? )
    connecting rods
    pistons
    Assembled weight for Mark IV SHP
    Assembled weight for Mark IV low horse
    Assembled weight for ZL-1
    Steve
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Major engine component(s) weight
    cast iron block 270#,ZL-1 block 110#, assy weight for a ZL-1 500#,closed chamber pistons 700 grams,open chamber pistons 660 grams
    • Steve Antonucci
      Thanks Clem ! Now I gotta figure the weight of the ci & alum. BB heads.
      Steve
      • Warren F.
        • December 1, 1987
        • 1516
        Steve,
        I have several factory LS-6 engine components. 3946074 heads assembled minus rocker arms & nuts, but with guide plates..35lbs each. 3963569 intake with oil splash shield and staked carburetor studs and both threaded water hose nipples...12lbs.
