First question:On the drivers side of the engine is a temperature sensor on the head. When I got the car in July 1999 the wires that go on this sensor were disconnected and taped up in a ball. I untaped the wires and found that the plastic holder/connector is gone. What exactly does this control? Is there a plastic holder/connector available? Does it matter which way the wires go on the sensor?
Second question: The automatic transmssion will not downshift(kick down) when the gas pedal is depressed to the floor. My research tells me that it is probably the detent switch. How do you check this switch to see if it is bad? The transmission works great and downshifts manually.
