C2 Fans:
I have a few questions about some of the decals and stickers that go on 1966 and 1967 C2s. Your help and comments are appreciated. Thanks.
1. For a 1967 small block 327/300 I believe the "Flint #1 Team" sticker is applied to the front of the right valve cover. Correct? Was there also an engine code (ie "HE") sticker applied to the rear of the right valve cover?
2. On a 1966 small block 327/300, I believe the carpet inspection sticker and the JP Stevens stickers go on the underside of the jack board. Correct? If so, where exactly do they go (the corner? the middle? anywhere?) Where are they in relation to each other?
3. 0n a 1966 small block 327/300, was a sticker bearing a part number applied to the front stabilizer bar?
Thanks again,
Jim C.
Thanks again,
Jim C.
