Brake Line Survey - February and Later 66's - NCRS Discussion Boards
  • Tim E.
    • April 1, 1993
    • 360
    If you replied to a similar message last week, thanks for your participation. If not and you own (or have access to) a February or later 66, I would appreciate your help.
    It appears that in about March or April 1966 (much earlier than I thought), the method used for securing the front brake crossover line to the frame crossmember switched from using a single wire clip mounted in 1 hole in the center of the frame crossmember to using 2 flat clamps. With the 2 flat clamp method, there are actually 3 holes in the frame crossmember. The brake line clips are bolted in a hole above each of the lower control arm nut plates. The center hole is there but unused.
    My June 15 car uses the 2 flat clamp method and has all 3 holes ( ) as does each car in the survey after May 9. A February 24 and an April 7 car both use one spring clip in a single hole ( ).
    A favor please: If you have a February or later 66 and are (reasonably) sure your front brake line is mounted the way it was originally, I'd appreciate hearing from you!
    The information that would be useful:
    VIN Number (e.g. 194676S124431)
    Build Date (e.g. June 15, 1966)
    Style of Hold Down Clamp (2 Flat Clamps or 1 Spring Style)
    Number of Mounting Holes in Crossmember (1, 2, or 3)
    Thanks in advance. I'll post the results after I tally the responses,
    Tim Ehlers
    tehlers@hess.com
  • Rob A.
    • December 1, 1991
    • 2126
    Re: Brake Line Survey - February and Later 66's
    My June 20 built '66 has 3 holes, center unused, with 2 flat clamps in the outer holes.
    • Philip C.
      • December 1, 1984
      • 1117
      19087 April 13 one spring one hole *NM*
      • Peter L.
        • May 31, 1983
        • 1930
        Tim - Add 1966 S/N 25,305 to your list of cars having the 3 holes and 2 clamps. Pete
        • Dave B.
          • April 30, 1984
          • 248
          Tim,
          My 1966 VIN 15679 with a March 4th build date has one spring style clamp and one hole.
          Dave
          • Jim L.
            • December 1, 1981
            • 50
            Hi Tim
            My 66 roadster SN20101, Built 25 April 66, One spring style clamp and no other holes. Car had never been apart prior to my frame off.
