1967 Corvette 427/435 Engine Pad - NCRS Discussion Boards
  • Richard J.
    • August 31, 2005
    • 83
    Hi,
    Can anyone tell me if this stamping looks original and correct? Does anyone have a picture of their stamping of a '67 427/435 near this serial number and would you be willing to share it with me? I am not sure about the "J" in the JE and I am not sure the 2 is correct in the VIN portion. Any help is greatly appreciated!!
    Rick
    Rick Jones
    Albuquerque, NM
    Member #44319
  • Mark #28455
    need to carefully strip off the paint
    The broach marks will tell much more of the story. In addition, check the casting number too as I think some 1969 396's also used the JE code.
    Mark
    • Jack W.
      • August 31, 2000
      • 358
      Re: need to carefully strip off the paint
      I think anybody selling a 67 L71 (435 hp) car as an original engine deal likely knows enough to clean the stamp pad, as it will be a deeply examined item - so much so that I now wonder a bit when I see a freshly painted pad on such cars. No offense to those with painted pads.
      • Steve Wallach
        Re: 1967 Corvette 427/435 Engine Pad
        It looks good to me, however I agree, the paint should be stripped using brake cleaner or paint thinner / stripper. The "Broach" marks will tell a lot more.
        Al Grenning will be able to tell for sure.
        Good Luck,
        Steve
        • Mark K.
          • January 1, 1983
          • 148
          I hope this image helps. This is from an unrestored 67 435HP engine.
          1967 L71 Silver/Black Coupe - Unrestored/Original Paint, Top Flight at 1998 Regional in Ontario, not judged since
          1995 Red/Red ZR-1 - Top Flight back in 2010 Michigan Chapter meet
